01-22-2021
19:28
03:56
01-22-2021
19:28
03:56
8.10 yesterday morning syncing stopped between my fitbit versa lite and Oppo a53s phone. The watch was purchased in July 2020 and the phone in November 2020. Syncing has stopped in the past and was easily fixed by un-pairing and re-pairing the bluetooth. Unfortunately not so easy this time as the watch is not even visible by the phone so nothing to pair too. The phone can pair with other devices so presumably not a problem with the phone. Both the phone and watch have been powered down and restarted, both the phone and fitbit are up to date. The phone is connected to wifi, bluetooth is on
Can you please advise on further actions? Syncing issues appear to be quite common so hopefully there is an easy fix!
Thanks
Moderator Edit: Personal info removed
01-23-2021 04:00
01-23-2021 04:00
Hi @MossyCat, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa Lite before reaching out.
Before anything else, please note that your Oppo A53s is not yet supported by the Fitbit app which would explain the syncing difficulties you're running into. To see the list the compatible devices, see Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported and does not meet the require OS we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
In addition to the steps you've tried, I'd recommend the following:
Hope that helps.
01-23-2021 17:17
01-23-2021 17:17
Hi,
Thanks for your suggestions. Unfortunately nothing worked ☹️ and now when I try to set up the watch in the app (with the phone bluetooth on and watch charging nearby) it fails in the search. I have now had an opportunity to install the fitbit app on a Samsung J1, iphone 5S and iphone 10x. On each of these phones the app fails to find the watch. Each phone can successfully pair to other devices. I have checked the watch settings and settings>bluetooth has been tested as "on" or "pair". So is there a possibility that there is something wrong with the watch bluetooth? Or is there something really basic I am missing?
Thanks
Donna
01-24-2021 06:40
01-24-2021 06:40
My versa will not pair to any device right now either. I have tried all of the trouble shooting options and nothing is working. Very frustrated!!
01-25-2021 04:27 - edited 02-26-2024 03:34
@MossyCat Please note that the Samsung J1 is also not compatible with the Fitbit app. Now, with the iPhone 5S and iPhone XS, you can use either of those. However, I suggest to choose one to complete the following steps as using both or more than one mobile device may cause trouble due to the Bluetooth interference.
That being said, please try the same steps I recommended above:
@Bnelson3 I totally understand how you must be feeling. Thanks for trying to troubleshoot your watch, I've seen you got in touch with our Support Team after posting here. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you.
01-25-2021 20:34
01-25-2021 20:34
Hi and thank you for your suggestions. Yep I have gone through that process one by one with each of the phones mentioned but without success. As the watch is still under warranty I have decided to return it as faulty. I have persisted with a fitbit at this stage and the new watch (now a Versa 2) seems to be happily connecting with the OppoA53s. We also tested it on the iphone 10 and it worked well there too. As I have no intention to change phones right now (only bought it 3 months ago!) this may be a bit risky but I will always have access to the two iphones to test following the instructions above.
Thanks for your assistance
Donna
01-26-2021 04:48 - edited 08-31-2023 05:25
@MossyCat You're very welcome! I'm glad to hear the retailer where you bought the Versa Lite from exchange it for a Versa 2 which is working as expected.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
