02-01-2024
07:18
03:46
02-01-2024
07:18
03:46
Not recording sleep, heart rate or active minutes. I’ve tried a restart and nothing has worked.
Best Answer02-02-2024 03:52
02-02-2024 03:52
Hi there, @Ada1143. Thanks for stopping by in the Fitbit Community Forums and already trying to troubleshoot the issue with your Versa Lite before reaching out. I will do my best to continue assisting you with this.
As a first approach, I'd recommend trying the following steps to make sure your heart rate is working:
In addition to that, I suggest taking a look at this help article Why don't I see sleep stages today?
I am suggesting to make sure that the heart rate is working fine as sleep stages and active zone minutes are based on your heart rate readings.
I will be around if you need further assistance.
Best Answer02-03-2024 08:16
02-03-2024 08:16
Same problem. Downloaded a new clock face. Mine is now working
