12-01-2024
07:03
05:31
12-01-2024
07:03
05:31
My Versa Lite shows no Sleep-datas and no Heart-Frequency. Non from The LED in the backside of the watch send lightning. The LED have no function it seems or have Google the LED Switching Off?
Best Answer12-01-2024 21:34
12-01-2024 21:34
Hi @Rudy-maus5 - you can disable/enable Heart rate detection in the watch settings so check that and restart the watch.
If it is still not detecting heart rate the watch may have a fault, especially if it got wet.
While a factory reset is possible, it may fail and if you live in the EEA you might not be able to reinstall all you had before and it won't fix a hardware fault. So only use as a last resort.
Best Answer12-02-2024 00:34
12-02-2024 00:34
12-02-2024 01:43
12-02-2024 01:43
@Rudy-maus5 - thanks, you could always trying drying it (in some rice for a week or when not using it) it may or may not improve the situation. But don't get it wet again.
