05-24-2021
14:50
04:10
05-24-2021
14:50
04:10
After swimming in a pool for the first time this summer with versa lite, it has had black screen and no manual reset has worked. I have tried charging to full power and then doing factory reset for several days but no luck. Today the screen finally showed 0% battery so I again tried charging but now I think it is my charger not working. what can I try next?
05-25-2021 04:13
05-25-2021 04:13
Hi there, @Ciancic. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa Lite before reaching out.
In addition to the steps you've done so far, please try the following:
Hope that helps.
05-25-2021 06:52
05-25-2021 06:52
None of that worked. What do I do now?
05-25-2021 07:15
05-25-2021 07:15
Hi there, @SunsetRunner. Welcome on board. I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
05-28-2021 09:46
05-28-2021 09:46
I swam yesterday and the same thing happened. Since it is out of warranty they are only offering a 35% discount on a new device and not replacing the device. This is the 2nd time this has happened. Do not believe them when they say you can swim with it
05-31-2021 19:20
05-31-2021 19:20
Update: after a week my Fitbit finally turned on while on the charger. The screen now functions but after removing the device from the app and syncing a few times it still does not register steps and heartbeat. Any suggestions on what to do now?
06-01-2021 05:00
06-01-2021 05:00
Buy a smart watch that actually is waterproof. My Blaze died after swimming, took the back off water got in from the speaker hole.
06-10-2021 05:53
06-10-2021 05:53
They shouldn't advertise that it can be used for pool swimming/fitness if it is only sweat proof.
06-10-2021 05:55
06-10-2021 05:55
AGREE. This is clearly a manufacture defect. It happened to me twice (the 2 times that I tried to swim with the Fitbit Versa Lite). The first time I thought it was just my fitbit so I unfortunately swam with the replacement and the same thing happened....black screen/dead. Unbelievable they won't stand behind the product and continue to falsely advertise. I want my $ back or the item replaced.
06-10-2021 16:16
06-10-2021 16:16
I decided because of that that I would purchase my very first Apple Watch! Great customer service and I’ve already been swimming with my Apple Watch!
06-11-2021 12:18
06-11-2021 12:18
Yes...my oldest daughter has her 15 month old in ISR (infant swimming) and several of the instructors wear Apple Watches. My son does triathlons and wears a Garmin Forerunner. Glad there are options that don't falsely advertise like Fitbit and deliver what they promise.
06-14-2021 08:04
06-14-2021 08:04
The same thing happened with mine. They said it was swim proof. I went swimming with it, it wouldn't turn back on. I tried charging it, manually resetting it. Now it will turn on but the step tracker and heartbeat will not register. Was told the same thing, would only offer 35% off a new device. Why would I buy another device when they're clearly selling defective devices that are being marketed with lies. I will never own another fitbit.
06-14-2021 11:21
06-14-2021 11:21
Ok that has happened to me too but it was in the pool for 3 seconds and nothing happened until a few days ago the time is wrong and it takes twice as long as it used to
06-14-2021 11:26
06-14-2021 11:26
It takes twice as long to turn on
06-15-2021 10:11
06-15-2021 10:11
EXACTLY!! And the product may be fine for other things… But don’t advertise that it works for swimming. It clearly is a manufacture defect and they should refund dollars, or replace the device and you just know that you can’t use it for swimming
