08-06-2021
01:35
05:43
08-06-2021
01:35
05:43
I wore my Fitbit Versa Lite in a pool after reading that it was water resistant to 50m. Now it will not turn on. I've found water droplets seeping out between the bezel and the screen. Really disappointed with the quality of the product and I've tried everything to dry it out with no success.
08-06-2021 05:44
08-06-2021 05:44
Hi there, @Gezagonk. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa Lite before reaching out. I understand how disappointing this can be.
In addition to the steps you've tried so far, I'd recommend restarting your watch by following these steps How do I restart my Fitbit device?
If the restart doesn't work, let's move forward with the steps below:
Hope that helps.
08-06-2021 05:44
08-06-2021 05:44
Hope that helps.
08-06-2021 11:46
08-06-2021 11:46
That doesn't really work when water is still dripping out of the Fitbit. It's a bit dangerous recommending that I connect it to a power source. These devices are not cheap and I am shocked by the build quality. So basically bin the device then?
08-06-2021 15:04
08-06-2021 15:04
@Gezagonk I understand where you're coming from.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
