07-12-2019 11:22 - last edited on 07-14-2019 15:29 by LiliyaFitbit
I performed an update on my Ipad (unrelated to my Versa) and my Versa Lite went crazy. The screen started pixelating, and I couldn't do anything with it. Now the Fitbit will do nothing. The only thing that will come up on it is 0% battery, although I have fully charged it. When I try to sync it to the Fitbit App the app can't find the Fitbit. Any suggestions?
06-16-2020 04:02
06-16-2020 04:02
I bought Fitbit versa lite and it's one of the worst smart watch I have ever seen. Nothing works in it. It will switch on. If we somehow switch it on...it will not connect with mobile. If we connect to the mobile(Fitbit app) , it will not sync the data. Also it will not provide any notifications. It's one of the worst smart watch( Fitbit versa lite). I don't recommend it to any one.
06-16-2020 05:34
06-16-2020 05:34
06-16-2020 05:46
06-16-2020 05:46
06-16-2020 17:31
06-16-2020 17:31
My fit bit is doing the same thing, resetting does not work, only 5 months old, not happy
06-16-2020 17:32
06-16-2020 17:32
Mine on Android is the same, I have tried everything
06-16-2020 17:35
06-16-2020 17:35
My fit bit has not worked for over a week, I charge it to 100 percent and try updating, says my battery is dead, deleted and try to re sync fit bit over night still not finished updating now 6 days in a row, I bought this as a Christmas present for myself, so upset, this was a splurge for me and I can't even use it
06-16-2020 17:37
06-16-2020 17:37
This does not work, this is garbage, it's less than 6 months old!
06-16-2020 17:40
06-16-2020 17:40
This is what mine is doing too, I can't get any answers. Started a week ago, I have deleted it and reinstalled it, no lunch, keeps saying battery is dead, charging over night, very frustrating, can't seem to find any help
06-16-2020 23:18
06-16-2020 23:18
06-16-2020 23:35
06-16-2020 23:35
08-11-2020 04:31
08-11-2020 04:31
My screen is black, I bought it on January, it worked all good. Battery was 98%. I did back button resetting, clock face changing nothing worked
11-03-2020 14:28
11-03-2020 14:28
I have a Versa Lite. I am having all the same types of problems. Mine is nearly 10 months old. It quit syncing. Then I can't connect to it and now it is off/on, dead battery, no function. Says reset failed. Won't respond to anything now. It went bonkers before I did the update. Planned obsolescence? Its still under warranty, right?
11-03-2020 16:26
11-03-2020 16:26
Hi,
I have posted here that my versa stopped working and you guys sent me a new one, and that one has stopped working as well! What do I do now?
05-02-2021 21:41
05-02-2021 21:41
My versa lite won’t turn on or sync. My app just keeps saying it’s looking for the device I have tried everything you have suggested and it will still not work. This is frustrating I use my Fitbit all the time to see notifications for work and now I can’t. What am I supposed to do?
08-09-2022 20:21
08-09-2022 20:21
Mine is flashing the Fitbit logo but nothing else. I tried turning it off but it doesn’t work. It started at 7am this morning after syncing.
