06-17-2021
02:34
12:19
06-17-2021
02:34
12:19
My Versa Lite is showing an error message: "Data not cleared.Sync and try again". I have been trying to sync and nothing happens. My device is paired to my phone but it wont connect. This happened after I updated the app.
06-19-2021 03:00
06-18-2021 12:23
06-18-2021 12:23
Hi there, @MJ84. Welcome to the Community Forums. Thanks for the details provided in your post.
Please note that the error message you're receiving on your watch's screen usually appears when you've performed a factory reset without first unpairing the watch from your Fitbit account. With that being said, I'd recommend the following to solve the issue:
If you can't get started with your Versa Lite, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
06-19-2021 03:00
06-19-2021 03:00
Thank you.
Will try this.🙂
