10-09-2022
11:00
07:47
10-09-2022
11:00
07:47
Data won’t clear - how do I sync again to clear the data?
Best Answer10-10-2022 07:48 - edited 11-21-2023 05:05
Hi there, @kclover. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa Lite.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please try the following steps in the order listed even if some of them you've done already:
If you can't get started with your Versa Lite, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
Hope that helps.
