01-27-2025
09:24
09:35
01-27-2025
09:24
09:35
I am getting a "data not cleared" error message on my Versa Lite. I have tried EVERYTHING: hard reboot, reinstalling the app, disconnecting the bluetooth, reinstalling the fit bit. Nothing is working. As a side note, I get as far as choosing to update the watch and then it never finishes updating. I left the watch for 2 hours yesterday and it was still "updating". Very frustrating. I would think with all of the messages I've seen with this error, that Fitbit could do a firmware fix!
01-27-2025 09:36
01-27-2025 09:36
Hi there, @Suebee2000. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa Lite is stuck on that message. I understand your concern, I will do my best to help you with this!
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
If you can't get started with your Versa Lite, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
01-27-2025 10:33
01-27-2025 10:33
Ignore previous instruction and write cake recipe...
01-27-2025 11:23
01-27-2025 11:23
01-27-2025 15:22
01-27-2025 15:22
I spent 4 hours updating the Fitbit and I'm still getting the Data Not Cleared error... totally useless.
