02-10-2022
06:58
11:07
02-10-2022
06:58
11:07
How do I change the time to 5 minutes ahead? I checked to make sure it is on the correct time zone but do not know how to move the time forward by 5 minutes?
Best Answer02-10-2022 07:05
02-10-2022 07:05
Hi @Berleyk the time comes from the device you used to set up and sync. Try syncing a few times, restart the device and the app. It should correct itself.
Best Answer02-10-2022 19:52
02-10-2022 19:54
02-10-2022 20:11
02-10-2022 20:11
@Berleyk - the title of this topic was changed and may not be what you intended.
You can go in on the gear icon or 3 dots and edit your original post and change it if you want, in case someone else has a solution to offer.
Other people have asked to have a time offset and may have found a solution.
