08-07-2019 12:42
08-07-2019 12:42
App is fine - exercise and sleep is showing - however watch never updates
Best Answer08-08-2019 05:29
08-08-2019 05:29
@jmoran888 welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it's not syncing your exercise and sleep.
I'd like you to try the troubleshooting steps that are listed in this help article. After this, monitor your Versa for the next 48 hours and see if the issue gets fixed.
Keep me posted on the outcome! ![]()
Best Answer08-08-2019 06:10
08-08-2019 06:10
Hi thank you for your reply. So the steps/and steps per hour are syncing fine. Its just the exercise and sleep functions that are NOT syncing.
Thanks!
Jennifer
Best Answer08-12-2019 10:03
08-12-2019 10:03
@jmoran888 I'm sorry for the late response. However, I appreciate your response.
Since your sleep and exercises are not being synced, I'd like you to make sure that your phone has the most recent Fitbit app version installed. If the app is up to date, try logging out of the app, restart your phone, open the app again and log in.
Finally, try setting up your Versa from scratch (make sure to sync your watch before this in order to avoid losing current steps, and stats). After this, use your Versa as you regularly do and see if your exercises and sleep sync properly.
Let me know how it goes! ![]()
