07-03-2020
03:35
06:43
07-03-2020
03:35
06:43
I have only had my versa light for a couple of months. Loved it at first, then a few weeks ago installed the update. Since then it wouldn't hold a charge for more than a day Max, some days had to charge more than once, and stopped reading heart rate, even after restarting. This morning after charging all night I can't even get it to turn on.
Best Answer07-04-2020 06:45 - edited 06-19-2024 05:24
Hi there @Aa6, welcome to the Community Forums. I'm sorry to hear about your Versa Lite's recent behavior. Thanks for the details provided in your post and for taking the time to troubleshoot your watch prior to posting here, I'll be glad to help you.
As per the description of your post it seems that the battery of your Fitbit may not be charging properly and therefore does not turn on. I recommend that you follow these steps (or please confirm that you've followed them as described below):
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Best Answer07-05-2020 19:44
07-05-2020 19:44
Best Answer07-06-2020 04:37 - edited 10-12-2023 02:59
Hi there @Aa6, thanks for the update. I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
