08-06-2022
00:48
04:19
08-06-2022
00:48
04:19
My Versa lite has stopped syncing. It had been going on and off for months. Tonight, despite logging on and off and reinstalling the app, nothing is working. It's not visible to my phone at all. Does anyone have any tips? Thanks
08-06-2022 04:22 - edited 06-28-2023 10:13
Hi there, @RachSn. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Versa Lite before reaching out. I understand where your concern is coming from.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa Lite from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa Lite.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa Lite.
