08-03-2020
12:47
11:37
08-03-2020
12:47
11:37
I have a versa lite and I’m trying to get an app on it. However, in the Fitbit app it is saying either my versa or my app is not update to when both of them are. What can I do? I really need this app and there is no other option
Best Answer08-04-2020 11:42 - edited 10-12-2023 18:48
Hi there @amberviolet12, welcome to the Community Forums. Thank you for the details provided in your post and for taking the time to verify that you have no pending updates to install. I'll be glad to help you to download the apps on your Versa Lite.
While reading your post I was wondering if the app you're trying to download is Spotify? If so, note that in order to install Spotify app, your watch must be updated to the latest Fitbit OS 4.1.3 (32.70.8.0) and the Fitbit app on your phone to 3.26.1. May I know what is the version currently installed on your watch? You can find it either by going in the , tap the Today tab > your profile picture > your device image (the firmware version number appears under your device's name) or on your Versa Lite, in the Settings app > About or Device Info.
That said, leave on all-day sync and let the Fitbit app run in the background on your phone, which allows a small portion of the firmware update to download to your Fitbit device each time you sync. To check that all-day sync is turned on: In the Fitbit app, tap the Today tab > your profile picture > your device image > confirm All-Day Sync is on. Once you have updated your Versa Lite you will be able to download the Spotify app, check this article to know how it works.
