06-23-2020
17:31
13:25
06-23-2020
17:31
13:25
I have a Versa lite that started giving notifications late and now it doesn't sync and can't get it to pair with my Pixel 2. My Pixel 2 is running Android 10 and the fitbit software is up to date. I've tried deleting the fitbit and attempted to pair it but can't get my phone to recognize it. Works fine with my Pixel buds but and any other bluetooth device. Tried restarting the fitbit and it doesn't work. Any help would be appreciated.
Best Answer06-24-2020 13:29 - edited 03-03-2024 09:41
Hello there @Fred93gt, welcome to the Community Forums. Thanks for the details provided in your post about the connectivity issue between your Versa Lite and your Pixel 2. I appreciate you've taken the time to try fixing the issue, I'm here to help you.
If you haven't done so yet, I'd recommend trying the following steps:
If you can't get started with your Versa Lite, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Best Answer06-24-2020 16:57
06-24-2020 16:57
Best Answer06-24-2020 18:28 - edited 03-03-2024 09:34
Hello there @Fred93gt, thanks for getting back and for the update. Since you've exhausted all troubleshooting, you can try performing a factory reset on your watch. Note that when doing a factory reset you'll need to reinstall any apps on your device after, and if you couldn’t sync your device, then any data on the Fitbit device will be since the last time sync. Before doing so, I recommend making sure that your Versa Lite is no longer paired/linked to your Fitbit account and phone's Bluetooth settings (like I mentioned and suggested above), then perform the factory reset. For instructions, see How do I erase my Fitbit device?
Once done so, please try to set up your Versa Lite and see how it goes.
Keep me updated on the outcome.
Best Answer06-24-2020 19:11
06-24-2020 19:11
Best Answer06-25-2020 03:04 - edited 10-11-2023 18:17
Hello there @Fred93gt, I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
