07-01-2022
12:30
14:58
07-01-2022
12:30
14:58
its been a week since there were problems when synchronizing my fitbit versa lite with my phone, when i was reading today about the issue, i found that maybe i should forget the device and pair it again, however since then my versa lite isnt appearing when i follow the steps to set it on my device when i reach the bluetooth isn’t finding it, i tried it on another device had same problem, what should be the issue?!
Best Answer07-01-2022 15:00
07-01-2022 15:00
Hi there, @NZZ. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa Lite. I understand where your concern is coming from.
While I was reading your post, it seems that your Versa Lite won't connect to your phone again as you have unpaired your Fitbit device from the Fitbit app, but not yet from your phone's Bluetooth settings. With that being said, I suggest trying these steps in the order listed:
If you can't get started with your Versa Lite, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Note: Please make sure the mobile phone you're syncing with meets the requirements listed here.
Hope that helps.
07-01-2022 15:00
07-01-2022 15:00
Hope that helps.
07-07-2022 11:59
07-07-2022 11:59
Hello, i tried everything that you already said, nothing seems to work, i even tried connecting the device on another phone it didnt work, i tried to connect another fitbit(hr inspire) on my phone and it worked, so the problem is not from the phone or the application, the problem seems to be from the versalite itself, i contacted the shop where I bought it, they told me to contact you online in ordere for you to check the watch and see where the problem is from, so mainly I am waiting for your help please. I event reset the watch however no result!
Best Answer07-07-2022 12:16 - edited 07-18-2023 10:33
@NZZ I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
