08-17-2021
11:44
06:14
08-17-2021
11:44
06:14
Fitbit won't update after factory reset. Also would not keep correct time.
08-21-2021 06:18 - edited 10-02-2024 09:10
Hi there, @Wildman5. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa Lite.
If you performed a factory reset on your Versa Lite without first unpairing it from your Fitbit account and phone's Bluetooth settings, that would explain why it's no longer syncing nor keeping the correct time. With that being said, please try the steps below:
If you can't get started with your Versa Lite, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope this helps.
Hope this helps.
10-21-2021 02:04
10-21-2021 02:04
I've had a versa lite that was not used for months, Once I started using it again it did not get synced with my phone. Once I did a factory reset the whole watch just stays on the screen that says download Fitbit app. I have tried everything that you've mentioned. I still cant get my watch detected on my phone. I also tried multiple phones same issue,
