07-13-2021
00:10
04:59
07-13-2021
00:10
04:59
My app won't sync with my fitbit and my time is now running 25minutes slow, any help appreciated.
Best Answer07-13-2021 05:27 - edited 01-27-2024 13:22
Hi there, @Shel17. Welcome to the Community Forums.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try what @Guy_ has suggested you or you can also try the following:
1. Remove the Versa Lite from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa Lite.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa Lite.
Hope that helps.
Hope that helps.
