07-30-2020
10:58
04:34
07-30-2020
10:58
04:34
We've had this watch for less than a year, and for most of that time it hasn't been used. I booted it up yesterday and did a factory reset (my boyfriend is letting me have it, so I reset it to clear his data off of it). As soon as I hit the reset button, it turned off and now will not turn back on. I had it on the charger over night, even went today and bought a new charger in case that one was faulty. It doesn't vibrate when put on the charger. Any advice would be appreciated.
07-31-2020 04:42
07-31-2020 04:42
Hi there @Court_Nic, welcome to the Community Forums. I appreciate the details shared in your post about the Versa Lite's behavior and for taking the time to troubleshoot it prior to posting here. Thanks for letting me know that you've also bought a new charger.
Have you tried restarting your watch as @Rich_Laue suggested?
Since the Versa Lite isn't vibrating when you connected to the charger, it seems that the Factory Reset drained the battery but also looks like it may not be charging properly, therefore, it does not turn on. I recommend that you follow these steps:
I'm looking forward to your response, keep me posted.
07-30-2020 20:47
07-30-2020 20:47
Did you do a restart ?
This is how to turn on the tracker
07-31-2020 04:42
07-31-2020 04:42
07-31-2020 22:17 - edited 07-31-2020 22:20
Hello!
Thank you for the help. I have tried restarting many times, but no matter how long I hold the button down, it never boots up. I tried cleaning it like you suggested, and have noticed no difference. I decided to plug the charger into my laptop just to see if it's even trying to connect to anything via the cord (I did this yesterday when initially booting it up before the reset, and it connected normally). When it's plugged into the laptop, it makes the connect and then disconnect sound over and over again. It doesn't do this unless I put the Fitbit in the charging dock. I've tried even holding it in place on the connection points and opening the dock up just enough to hold down the power button while it's attached to the connection points. It had been charging and turning on just fine yesterday until the reset, so I'm worried I somehow made it unable to charge or boot up. On the Fitbit app, it's still showing as registered under my boyfriend's acct and showing battery empty. Any other advice or suggestions?
Thank you so much.
08-01-2020 04:24
08-01-2020 04:24
Hi there @Court_Nic, thanks for getting back and for the update. I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
We hope your issue is solved soon.
08-02-2020 01:47
08-02-2020 01:47
Thank you so much for your help!
