07-02-2022
10:24
12:00
07-02-2022
10:24
12:00
I have had my fitbit versa lite for over 2 years and the first year I had it, it wouldn't update after having it for a few months, got it fixed and 2 years later now it won't charge or turn on. I absolutely love this watch but I don't have the money to replace it despite having it for over 2 years.
Best Answer07-02-2022 12:24 - edited 03-25-2024 07:33
Hi there, @Jasminemw9395. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa Lite. I understand where your concern is coming from.
As @SunsetRunner has suggested, I'd suggest trying the following steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Best Answer07-02-2022 11:46
07-02-2022 11:46
Hello @Jasminemw9395
Its possible that the charger is bad and needs replaced. Look closely at the pins…do they look bent? Inverted inward? Maybe it simply just needs cleaning. Look at directions on image below) If the charger is bad it certainly won’t charge your Versa lite. You can purchase replacement chargers on Amazon for a reasonable cost: https://www.amazon.com/EXMRAT-Fitbit-Versa-Charger-Charging/dp/B07RLRW2JV/ref=sr_1_4?keywords=fitbit...
Also check the back of your Versa Lite. It’s conman to have bits of dust and debris but it’s important to keep it clean to get a good contact with a functioning charger. It’s quite possible it needs cleaning as well. Look for tips on cleaning your Versa lite image below) If the problem persist after a good cleaning then I’d consider taking a chance on a new charger. It’s certainly cheaper then replacing the Versa Lite. Of course there’s no guarantee as it may be the Versa Lite has lived it’s lifespan
🤞😉 I’m hoping it’s just needs a bit of cleaning. Fingers crossed. Let me know how it goes
Best Answer07-02-2022 16:02
07-02-2022 16:02
This actually started a few days ago I went to the lake and I had it in the water for like 2 seconds, it even says "water resistant" on the back of my device and I took it off and let it dry in a bag of rice. After that it started glitching and the screen got dark and now it won't turn on or charge.
Best Answer07-02-2022 18:36 - edited 11-16-2023 04:22
@Jasminemw9395 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
