07-08-2022
18:51
05:47
07-08-2022
18:51
05:47
I have a 2 year old versa lite that went die today I have changed it and it is not charging or turning back on
07-09-2022 05:48 - edited 11-19-2023 03:40
Hi there, @Rcarroll416. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa Lite. I understand where your concern is coming from.
If you haven't done so yet, I'd suggest trying the following steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa Lite from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Hope that helps.
Hope that helps.
07-09-2022 13:01
07-09-2022 13:01
Tried all that nothing worked.
07-11-2022 06:48 - edited 11-16-2023 10:38
@Rcarroll416 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
