10-02-2022
17:55
09:33
10-02-2022
17:55
09:33
My Versa Lite just stopped working and never turned back on. The screen remains black even after I’ve charged it and tried resetting it - still, nothing. Can anyone help with this?
Best Answer10-03-2022 09:34
10-03-2022 09:34
Hi there, @Jcruz09. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa Lite before reaching out. I understand where your concern is coming from.
In addition to the steps you've done so far, I'd suggest trying the following steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Hope that helps.
10-03-2022 09:34
Hope that helps.
