07-08-2020
20:15
09:08
07-08-2020
20:15
09:08
My versa lite wont turn on
Best Answer07-09-2020 09:11 - edited 06-08-2024 11:26
Hi there @Mario1940, welcome to the Community Forums. Thanks for the details provided in your post, I'll be glad to help you with your Versa Lite that is not turning on.
As per the description of your post it seems that the battery of your Fitbit may not be charging properly and therefore does not turn on. I recommend that you follow these steps (or please confirm that you've followed them as described below):
Give this a go and let me know how it goes, I'll be around.
Best Answer07-09-2020 09:19
07-09-2020 09:19
Best Answer07-09-2020 09:41 - edited 06-08-2024 11:24
Hi there @Mario1940, thanks for getting back. I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
We hope your issue is solved soon.
