08-20-2020
14:13
09:53
08-20-2020
14:13
09:53
I charged my Versa light last night this morning I went to turn it on and it would not. I read all the tips and cleaned it with alcohol, let it dry. Held the buttons down and even tried to charge for a couple more hours by changing the outlet. Nothing has worked please help.
Cori Poulsen
08-21-2020 10:01 - edited 06-21-2024 04:17
Hi there @Coripoulsen, welcome to the Community Forums. Thanks for the details provided in your post about your Versa Lite's screen behavior. I appreciate you've already taken the time to troubleshoot your watch prior to posting here.
While reading your post I was wondering if your Versa Lite vibrates when you connect it to the charger? If it's not, please confirm that you've troubleshooted your watch as described below:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
