12-01-2019
12:08
13:27
12-01-2019
12:08
13:27
I reset to factory settings and will not finish, update or anything. It’s basically useless. Any ideas? I’m ready to return it to its maker.
04-10-2020 19:30
04-10-2020 19:30
Thanks! How did you do it through your computer?
04-10-2020 22:19
04-10-2020 22:19
It works fine now, I’ve just not tested sinking via my phone.
it took a lot of going back and forth with fit bit, as their instructions were not clear but we got there.
Thanks for getting back to us. We appreciate your efforts. Thanks for the photos. The USB Recovery can be found at the Fitbit app. You need to download the Fitbit app through the Microsoft Store. Please follow these steps to download it:
1. Go to http://www.fitbit.com/setup.
2. Scroll down and look for Don't have a mobile device available?
3. Click Download from Windows Store.
4. Once on the Windows Store or Microsoft Store, click Get.
5. Click Install.
6. Click Launch. Login to your Fitbit account.
After you have logged in, please follow the steps we have provided for the USB firmware recovery.
We hope this helps. Let us know how it goes.
04-10-2020 23:38
04-10-2020 23:38
04-11-2020 01:46
04-11-2020 01:46
I’ve added the steps given from
for bit. Pop it into your charge cradle and plug into pc
04-11-2020 06:29
04-11-2020 06:29
04-15-2020 10:28
04-15-2020 10:28
It's still not working it dosent move from the download the the app screen
04-23-2020 11:54
04-23-2020 11:54
Its still not working do you have any more tips.
04-29-2020 14:41 - last edited on 07-05-2020 17:41 by LiliyaFitbit
Followed your instructions I'm at step 2 of 3 for setting up and it never goes past 3%
Moderator edit: format
04-29-2020 15:01
04-29-2020 15:01
Any idea on how to do this on a chromebook...
05-13-2020 10:57
05-13-2020 10:57
I have the same problem so annoying,it keeps saying hold all three buttons but my Fitbit Versa lite has only one button,I have been onto Fitbit all day but no one seems to help please help
05-13-2020 11:00 - last edited on 07-05-2020 17:41 by LiliyaFitbit
I have done all that but it’s not asking to replace it,it even asked me for the four digit code but then it tells me they can’t connect
05-13-2020 11:05
05-13-2020 11:05
Can you give me the number
05-27-2020 07:37
05-27-2020 07:37
still stuck. my fitbit doesn't even has any green blinking activity, please help.
06-07-2020 11:54
06-07-2020 11:54
Gets to 2% for 4 hours then fails 😞
06-26-2020 06:10
06-26-2020 06:10
My Versa Lite will not even let ME set up again after a factory restart. This is all I get, so I can’t even set it UP on my phone. Which is an iPhone XR.
06-26-2020 08:53
06-26-2020 08:53
07-05-2020 06:03
07-05-2020 06:03
I’m having the same problem. How did you resolve issue? Is there a pin on the back to push?
07-05-2020 06:04
07-05-2020 06:04
This did not resolve my issue.
07-05-2020 06:10
07-05-2020 06:10
07-05-2020 06:21 - last edited on 07-05-2020 17:42 by LiliyaFitbit
I found no fix. I end up buying an Apple Watch.
