12-15-2020
10:18
12:08
12-15-2020
10:18
12:08
My battery started showing a quick charge after going dead, then started showing the incorrect time, now will only work if it is on the charger. As soon as it comes off the charger, it will not work. Any suggestions?
12-15-2020 12:11
12-15-2020 12:11
Hello there @JessM20, welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa Lite.
Does your Versa Lite vibrate when you plug it into the charger? If it doesn't, please try the steps below:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
I'm looking forward to your response, keep me posted.
12-15-2020 12:26
12-15-2020 12:26
12-15-2020 13:01 - edited 01-10-2024 10:40
@JessM20 Please note that the "back button" refers to the only button you see on your Versa Lite.
12-15-2020 13:18
12-15-2020 13:18
