01-04-2020
14:30
16:53
DavideFitbit
01-04-2020
14:30
16:53
DavideFitbit
Recently I have noticed that I will not get any of my texts on my Versa Lite. I have checked everything on there that i know of. It used to work but all of the Sudden it's not working. Has anyone else had this problem?
Moderator edit: format
Best Answer01-04-2020 16:02
01-04-2020 16:02
This is happening to me too! I get all my other notifications except my text messages! Any idea how to fix it?
Best Answer01-04-2020 16:05
01-04-2020 16:05
Hi @shortygirl2004 @nattie0807 What phones are you guys using? If they are iOS on the latest update then read the pink banner at the top of all the forum pages.
Helen | Western Australia
Best Answer01-04-2020 16:10
01-04-2020 16:10
Best Answer01-04-2020 16:32
01-04-2020 16:32
Hi @nattie0807 Unfortunately the S10 note us not on the Supported Devices List so the problem may be related to that, but try all the suggestions in THIS Help Article on notification issues and see if you can get it working.
Best Answer01-04-2020 16:33
01-04-2020 16:34
01-04-2020 16:34
Best Answer01-04-2020 20:19
01-04-2020 20:19
@shortygirl2004 WHAT Android? Make and model
Best Answer01-05-2020 04:22
01-05-2020 04:22
Best Answer01-05-2020 04:46
01-05-2020 04:46
Its @shortygirl2004 who hasnt answered the question.
Best Answer01-05-2020 06:44
01-05-2020 06:44
I have a galaxy s10. I've tried restarting my phone, deleting and reinstalling the app, rebooting my versa and still not getting texts notifications.
Best Answer01-05-2020 18:28
01-05-2020 18:28
@Mamat835 The S10 should work. Check your setrings in your PHONE SETTINGS (not fitbit). There could be something there that is preventing your messages coming through. In my phone (which is an S8), under Lock Screen I have to have Notifications turned on, and in Notifications I have Messages turned on in App Notifications. Yours might be a bit different, but with a bit of luck somethjng there will work. Failing that, try all the suggestions in the Help Article I linked in my post above above.
Best Answer01-05-2020 19:26
01-05-2020 19:26
Best Answer01-05-2020 20:16
01-05-2020 20:16
@nattie0807 It may just be that tje phone is not a supported device and it just wont work no ,atter what you do.
Best Answer01-06-2020 03:05
01-06-2020 03:05
Best Answer01-06-2020 03:53
01-06-2020 03:53
Unsupported phones often DO work, but it is usually an update to phone or tracker that upsets tje connection, if/when it is upset. As the phone is not supported, no one is working towards getting it working again. Sadly thats the way it is. It may start to work again, or it may not. Sorry it isnt better news.
Best Answer01-08-2020 05:23
01-08-2020 05:23
I'm using a Samsung Galaxy 10e
Best Answer01-08-2020 05:24
01-08-2020 05:24
Me either. I have contacted Fitbit and still nothing. I get calls but no texts.
Best Answer01-08-2020 05:25
01-08-2020 05:25
I did that and still nothing for me. I went on a troubleshooting website they have and still no text messages.
Best Answer01-08-2020 05:26
01-08-2020 05:26
Mine worked before the updates.
