11-17-2018 00:18
11-17-2018 00:18
Ok so my Versa has started having a lot of issues. Basically it's almost like it has a mind of its own;
-Continually tries to flick between the clock face and next screen (looks like a visual stutter) Doesnt allow you to go to either screen
- When you try to get to the next screen yourself, it takes numerous attempts. If you get there, it'll select something automatically (often alarm) and not allow you to get out of it.
-wakes by itself even when set to manual
-when you have the clockface on, you can often see it scrolling through calories/steps etc by itself and extremely quickly
it's basically not useable right now.
I've rebooted it numerous times. I've let the battery die on it completely a couple times (this happens extremely quickly now ). As yet I havent seen the update.
Anyone seen anything like this or have any ideas on how to fix it ?
 Best Answer11-17-2018 01:11
                              11-17-2018 01:11
Try a factory reset using the settings app if you can get there OK (scroll down to About), but if you cant use the buttons. If this doesnt fix it contact Support (link in my signature)
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up.  Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
11-17-2018 08:25
11-17-2018 16:51
11-17-2018 16:51
for some reason the factory reset isnt working for me ?
Trying it exactly as you'r saying, but it's only getting to the reboot stage, no actual reset
 Best Answer11-17-2018 17:13
                              11-17-2018 17:13
If it wont do the factory reset you will need to contact Support (link in my signature).
The update hasnt come out to everyone yet (I havent got mine either)
11-17-2018 17:47
11-17-2018 17:47
ok so managed to do the factory reset. Re-set everything up and it's still doing all the same problems
Now what?
 Best Answer11-17-2018 19:38
                              11-17-2018 19:38
@Quaz I am afraid you will need to contact Customer Support to guide you through the next steps. This might be a hardware issue. Good luck.
11-18-2018 19:01
11-18-2018 19:01
Just an update
Spoke to customer service for quite some time (over an hour). After a lot of trouble shooting that I'd already done (reboot, factory reset etc) They are now sending me a new Versa
 Best Answer11-18-2018 19:03
                              11-18-2018 19:03
@Quaz I'm glad you're getting a new Versa! 😊
