08-15-2018 03:14
08-15-2018 03:14
My Samsung Galaxy S8 won't stay connected to my Fitbit Versa using Music via Bluetooth. Although I'm still able to receive notifications, I find it rather inconvenient as I use my Versa to unlock my phone via smart lock.
After pairing, the settings will return to off after five minutes, disconnecting my phone. I have to reconnect to my Fitbit every 5 minutes which is really unsettling.
Wish I could return this product but I've exceeded the 45 day return policy sigh.
Best Answer12-03-2019 01:57
12-03-2019 01:57
I have fitbit Versa since last week and also have this exact problem. Its the firmware on the fitbit that is the issue. You click pair and it connects, but if you leave it on pair it disconnects. In order to change it to ON, requires you to cycle through OFF first and there lays the problem. It disconnects you. They need to switch the control to ON first after PAIR. The trick of tapping twice quickly doesn't work for me. Fit bit needs to fix this, its pretty annoying.
12-03-2019 02:28
12-03-2019 02:28
The trick of tapping it twice worked for one day on my fitbit versa then I was back to square one again. I have now given up trying and hopefully fitbit will fix this issue asap!
Best Answer12-03-2019 02:43
12-03-2019 02:43
Best Answer12-03-2019 03:37
12-03-2019 03:37
The same problem with my Versa lite as well.
they are making fake product by price is still high. Never seen such bad product in my life.
