02-29-2020 08:29
02-29-2020 08:29
My versa is just a little over a year old and I have loved everything, but the last week I have had nothing but issues. It will not keep time and I can no longer sync it unless I delete it from my account and reinstall and it will work for a few hours and then its not connecting again and losing time. HELP!
02-29-2020 18:07
02-29-2020 18:07
Hi @MSharif71 , are you using a Third Party Clock Face? If yes, change it to one developed by Fitbit itself and restart your Versa and the problem should be solved, Erik
Best Answer03-01-2020 08:23 - edited 03-01-2020 08:24
@SunsetRunner I do not think its 3rd party I will check that I do not think I have any third party items on my fitbit
