03-27-2018
07:46
17:51
EdsonFitbit
03-27-2018
07:46
17:51
EdsonFitbit
I preordered the Versa but I have a few questions.
I’m assuming It has to be connected to wi-fi to download your playlist but after the music is on there you no longer have to be connected correct? If I have pandora, i can download my “offline lists” to the Versa and listen while running outside/not connected to wi-fi and not having my phone?
I use an interval running app which prompts running, walking, sprinting. Does anyone know if there is an app like that available in Fitbit OS? I looked through the apps and didn’t notice one but maybe I missed It. Thank you all!
03-27-2018 09:12
03-27-2018 09:12
@MadelynneDwrote:I preordered the Versa but I have a few questions.
Hi @MadelynneD,
Yes, you need WiFi to load the songs, but once on the watch, you don't need WiFi, only bluetooth for the headphones.
Pandora on the watch automatically syncs the top 3 stations, which are the ones that are "offline" in the Pandora app.
There is an app called HIIT that does some nice interval timing. But it was designed for the Ionic and will have to be tweaked for the Versa. I would feel confident that there will be something similar for the Versa upcoming. Hope this helps.
03-27-2018 09:12
03-27-2018 09:12
Hi @MadelynneD,
