Versa (SE) battery drains fast
Hey guys.
I am very disappointed with the battery life of the Versa SE. So I had the normal Versa, which was replaced with the SE as that one packed up. Since getting the replacement in May, I've noticed that I have to charge every two days. This is ridiculous as the previous one didn't do this. What could be the problem? I am using the sleep function and using Fitbit watch faces with no animations. Should this one also be replaced?
2 REPLIES 2
Hi @SunsetRunner, it's great to see you in our Fitbit Community! I'd like to follow up and help you with your Fitbit Versa (SE) since the battery is draining fast. I totally understand how you feel about this.
Please follow the tips that are listed in this help article in order to improve the battery life of your Versa. After this, monitor the battery's behavior of your watch and see if the issue gets fixed.
Keep me posted on the outcome.
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
Hi @JuanJoFitbit , I hope you are well.
I have tried the suggested tips to extend my battery life, but it does not seem to be helping.
What else can I do?
