04-18-2018 14:09
04-18-2018 14:09
Does anyone else have a Versa that seems to be easily scratching (on the screen)? I haven't even worn mine for 24 hours and I already have several scratches on the screen, one of which appears quite deep.
10-03-2018 14:29
10-03-2018 14:29
I've been the glass screen protectors on Amazon they don't last very long and break very easily but at least my watch is not scratched. The glass screen protectors I bought for my last Fitbit lasted forever but I haven't found a really long lasting screen protector for the Versa as of yet.
Best Answer10-03-2018 14:31
10-03-2018 14:31
That's a good idea I think I will order a bumper also I have a little bit of damage on the side where a bumper would cover
Best Answer10-03-2018 18:07
10-03-2018 18:07
Regarding Versa and Corning Gorilla glass:
I find as many reviews state that Versa has Gorilla Glass as those that say it doesn't. EG:
https://www.pcworld.idg.com.au/article/636084/how-does-fitbit-versa-compare-ionic/
"The Fitbit Versa is waterproof up to 50 meters but lacks the Gorilla Glass found in the Ionic. "
The only answer that has any real meaning is within Fitbits specifications for each product, and in this regard there is no mention of Versa or Ionic having Gorilla Glass. The proof is in the pudding, and given what owners actually experience, the Versa screen is soft enough to scratch easily, but hard enough to crack if dropped onto hard or soft surfaces. Which makes me think that there are multiple materials used, with the softer material being on the outside. I've had a Surge for over two years, and the screen still looks as pristine as on my Samsung Galaxy S8+, despite relentless abuse, drops onto hard floor tiles, bouncing around in various pockets while pushed up against a set of keys, dropped out of a car on a few occasions, a fall from my bike onto a gravel road and more. Corning Gorilla Glass 3 or higher IS very tough. It is not found on Versa.
https://www.fitbit.com/shop/versa#specs
https://www.fitbit.com/shop/ionic#specs
10-03-2018 20:09
10-03-2018 20:09
10-04-2018 05:19
10-04-2018 05:19
Wow... wish I knew that before I bought the Versa. I guess I thought in 2018 having Gorilla glass on an interactive display would be a given... too bad. Should have done my research
10-10-2018 15:42
10-10-2018 15:42
For those of you who have used screen protectors, what kind do you prefer? I have a liquid skin protector on my Charge 2, and that works ok, but it's not as smooth as a tempered glass protector. I don't have a Versa yet, but I'm considering getting one in the next couple of months, and I want to get a screen protector for it. Do you prefer the liquid skin (the sticker type), the tempered glass, or the bumper cases? I'm curious about the bumper, but I'm afraid it will make it look big and bulky. If I get a Versa I would get the rose gold, so I'd want a clear bumper (if I went with that), so I could see the color of the case. I've looked at tempered glass, but those look kind of thick, and I'm wondering if they stick out too much. So that brings me to the liquid skin protectors. Do they offer enough protection? I've seen on the forums several people have screens that have broken, so I'm wondering if the liquid skin would prevent that from happening, or if I should get either the glass or bumper. Thanks!
Best Answer10-10-2018 20:46
10-10-2018 20:46
10-11-2018 02:28 - edited 10-11-2018 03:06
I use a tempered glass screen protector and one of the slip on, slip off screen/ bumper protectors. With this type you don't need to remove the straps to put on and off. They are found on ebay for about £3.00.
Note this has to be taken off prior to charging! But its so easy and quick its not a problem!
11-29-2018 19:22
11-29-2018 19:22
Just received my Fitbit verse yesterday. I wore it to work today and I notice a bunch of scratches within a few hours of wearing. Im so upset. I’m glad I am not the only one who expertises this within a couple of hours. Did they replace yours?
Best Answer11-29-2018 20:11
11-29-2018 20:11
Best Answer11-29-2018 20:37
11-29-2018 20:37
Best Answer11-29-2018 21:20
11-29-2018 21:20
Best Answer11-30-2018 03:17
11-30-2018 03:17
No I didn’t see the option to do so. I may try to send it back or just get a protector screen and deal with it 🤦🏽:female_sign:. Thank you for your help!
Best Answer11-30-2018 03:23
11-30-2018 03:23
Thank you, I may do the same!
Best Answer11-30-2018 03:24
11-30-2018 03:24
Oh boy, ok thanks for the info!
Best Answer11-30-2018 17:56
11-30-2018 17:56
Best Answer12-09-2018 00:59
12-09-2018 00:59
I know it sounds dumb but try toothpaste. Leave it on your screen for 10 - 20 minutes and then wipe it off it really works i’ve Been doing it for months.
Best Answer12-09-2018 09:55
12-09-2018 09:55
Best Answer12-10-2018 09:33
12-10-2018 09:33
Yes- 2 weeks old. I contacted FITBIT and they won't do anything. I will be returning it to the store I purchased from.
Best Answer12-10-2018 13:29
12-10-2018 13:29
Good advice on the toothpaste. We used to use that to clean the old plastic rear windows on sports cars when they yellowed.
