Did it say what the error was? Usually it is to do with heart rate detection, so I will tell you a bit about what to do for that. Try your tracker firmer or looser. Move it on your arm - up the arm a little often helps, or some people have found on the inside of the wrist works best for them. You will need to experiment over a few nights to see what works best for you. The other thing to do is to restart your Versa several times (would try that first) Let us know how you go
Helen | Western Australia
Best AnswerHi,
Thanks for the reply,It keeps coming up with a server error.
I wear My versa on the inside of My wrist and pretty tight.
I suffer with an over acted bladder and wake 2-3 times a night so not sure if that is interrupting it.
Thanks
