01-13-2021
14:48
17:00
KateFitbit
01-13-2021
14:48
17:00
KateFitbit
Update 1/20/2021: We've updated to 100%
We started releasing Fitbit OS 4.2.1 to Versa, Versa Lite, and Versa 2 customers. This is a progressive rollout which means everyone will receive it at different stages. We roll out releases in phases as a cautionary measure so that we can monitor performance closely and make adjustments if needed.
*Firmware releases aren't distributed based on region or location and can reach anyone no matter where you reside.
WHAT’S NEW AND FIXED
Read our help article for the latest updates.
HOW DO I UPDATE?
Find step-by-step instructions for updating Versa smartwatch here.
If you run into any trouble updating your Fitbit device, review these troubleshooting tips. If you have issues after completing the update, try restarting the watch.
VERSA LITE users - If you have trouble updating the firmware:
Follow the steps in this help article where we outline troubleshooting steps just for Versa Lite.
We appreciate your patience while we work to roll this out to everyone.
03-09-2021 13:19
03-09-2021 13:19
I'm in the same boat.And very disappointed, been using fitbit for years! But I did not purchase a new device right away when the discount was offered and tried to keep troubleshooting because I've had the watch less than 2 years. Now they won't honor it. Ridiculous.
Likely it time for me to move on to the other platforms in town.
03-10-2021 01:30
03-10-2021 01:30
I’ve got the same also it’s not letting you restore it to factory settings I don’t know how yours
03-11-2021 08:06
03-11-2021 08:06
For my Versa, I just recently got the update notification. Yesterday morning 3/10/21, I began trying to update the device. Literally, I spent ALL DAY trying. Even when I went to work (battery was 100%), it was running the update again. It drained the battery all the way, while I was at work. Every time, all day it would go through the motions of updating then installing, and every time came the same result. First, an all white Fitbit logo doing nothing. Then, eventually, the START screen. You know, it says "To begin, download the Fitbit app" I TRIED EVERYTHING I could think of. Old version of the app, while charging, not charging, wifi, bluetooth... Not once could I get it to factory settings. It's like there is NO operating system on it now. Well, as of last night anyway. When I got home, I put it on the charger and figured I'll try again today. Before I left for work, I had put my old Charge 3 on the charger. So, I proceeded to connect that to my app, which is working, EXCEPT when I get a notification it won't vibrate. SERIOUSLY???! Anyway, I figured I might try the Versa again today, but to my dismay, after being on the charger all night the Versa is DEAD! I mean dead, it does nothing! Way to go Fitbit... all these years, and you still haven't figured it out. 👏
03-11-2021 08:39
03-11-2021 08:39
@Annebanann I keep trying to get the message to people NOT to do the update. It's such a shame that Fitbit won't stop the rollout of this update. I've suggested to moderators on here more than once that the sensible thing to do would be to halt it. By for whatever reason Fitbit still seem to keep pushing it out. Perhaps they are afraid that if they admit to the extent of the problem it will cause them even greater problems.
My suspicion is that anytime you get a firmware update for a fitbit device there is a risk it will fail and leave the device unusable. It has certainly been a problem for the last couple of updates so I have become cautious every time I see an update notification.
03-11-2021 09:27
03-11-2021 09:27
03-11-2021 09:39
03-11-2021 09:39
@FoleyJP I agree there doesn't seem to be anything in this update that makes it worth installing. Which is why I haven't on my original Versa which is now about 2 and a half years old so may well be getting close to end of life anyway. No need to accelerate that.
I read an article a while back that suggested the firmware updates sometimes fail because of a difference in the clock on the Fitbit device and phone (or whatever it is paired to). It's pretty clear looking back through the forums that updating the firmware on a Fitbit has always been a risky exercise with a proportion failing every time - without any way of recovering them. So it would seem that the process Fitbit uses for firmware updates is flawed, but they obviously don't want to / can't fix it. I think they just keep quiet about it and tough out the consequences each time.
A lesson I learnt a very long time ago as an IT facilities manager is to investigate any manufacturers software update before installing it on a live system and if in doubt simply not to install it. It's always harder to undo a change and in the case of Fitbit it is actually impossible to back out a firmware change.
03-11-2021 22:45
03-11-2021 22:45
My versa also got bricked via last 2 updates, first one just after warranty is over. Heartrate monitor stopped working. Had a long interaction with support on Twitter and email, bottom line - they don't care to fix or replace device. This is a known pattern with fitbit as I see so many users sharing this experience here. I saw on some forums where Garmin replaced such our of warranty devices if update bricks them. I wonder why fitbit chose to destroy their own goodwill by not fixing this issues
03-12-2021 00:52
03-12-2021 00:52
03-12-2021 05:02
03-12-2021 05:02
My Fitbit Versa has been taking and hour so far to finish I am about to throw it away
03-12-2021 06:16
03-12-2021 06:16
That’s really bad how old is your Fitbit they are so expensive to keep replacing all the time
03-12-2021 07:46
03-12-2021 07:46
I've only had it since July, its useless to me even as a watch. I'm so disappointed 😞
03-12-2021 07:54
03-12-2021 07:54
@Barbie0417 It will still be under warranty so I would insist on a replacement.
03-12-2021 08:04
03-12-2021 08:04
I called this number yesterday 0800 069 8505 mine is been replaced
03-12-2021 19:52
03-12-2021 19:52
03-14-2021 07:40
03-14-2021 07:40
This is sad, I should not have to charge my versa 2 every day when it isn't even a year old yet or have to deal with it freezing up constantly. Once I'm done with it, I'll be jumping ship. Thanks for a few good years Fitbit but you guys really messed up with this one.
03-14-2021 18:32
03-14-2021 18:32
I’m having this same issue now. I have tried to use both WiFi and Bluetooth. Neither is working. My watch is completely useless now. Please help.
03-14-2021 22:32 - edited 03-14-2021 22:33
Today marks 60 days since this horrid update broke my heart rate monitor.
I gave in and ordered a complimentary replacement Versa 2. It arrived in short time and it seems to work, despite me accidentally updating it fully. It's not clear if the firmware update permanently broke my first device. However, DO NOT update a replacement tracker if possible; other cases have repeated themselves AKA the update breaks them a second time. It's unclear who is the exception to the rule. If you can't afford to switch brands, I advise taking use of your warranty if possible.
I'm glad I have a working watch again, but Fitbit has still failed to address this mass failure of watches. Once mine fails, I won't be tricked into a third Fitbit device.
03-15-2021 19:47
03-16-2021 11:05
03-16-2021 11:05
Fitbit heart rate problem post-update is driving me nuts. The majority of my box fit workouts are now in ‘below zones’. I could be bent over breathless and it’ll still give me a reading of 84 BPM. This wouldn’t be an issue if it weren’t for the addition of ‘active minutes’ which are directly tied to the heart rate monitor - it’s so inaccurate & also demoralising during workouts!!
03-17-2021 09:39
03-17-2021 09:39
Have you seen this on the Fitbit homepage?........Smartwatches "The innovative features you "need" for a healthier life all on your wrist".
