Versa Smartwatches - Fitbit OS 4.2 Firmware Update (71.6.19)
Update 9/3/2020: This update should now be available to all customers. If you have any difficulty updating, make sure you are following the directions in this article, and then provide as many specific details as possible in your post so that we can assist.
We've started rolling out Fitbit OS 4.2 Firmware Update (71.6.19) for the Versa series.
We release firmware updates to all customers in phases. The update will be available to everyone soon, and a banner will appear in the app when you can install the update. If you don’t see the banner yet, check the app again later.
*Firmware releases are not distributed based on region or location and can reach anyone no matter where you reside. We do not recommend performing a factory reset to force the update to your device as your data will be lost and you may not get the update. Please be patient and wait until you see the update banner inside of the Fitbit app to begin the firmware download.
WHAT’S NEW AND FIXED
Release notes can be found here.
HOW DO I UPDATE?
Step by step instructions for updating your Versa device can be found here.
We recommend updating your Versa over a home Wi-Fi network as this can greatly reduce the time it can take to get set up. For more information on connecting your Versa to Wi-Fi, check out this article
If you run into any trouble updating your Versa I recommend reviewing these troubleshooting tips
Actively managing your weight? Find accountability buddies on the Manage Weight board
577 REPLIES 577
Since upgrading to the new firmware, something seems to be wrong with the UI in the "Today" app on the Fitbit Versa. The top screen of the Today menu only shows an empty blue circle. Then only when I swipe right can I see my activity stats.
My versa lite was replaced after it wouldn't sync following an update. Now my replacement is only syncing sometimes and wont update. I've updated the app, switched bluetooth on & off and restarted the tracker. Any suggestions? I have a Samsung S8 phone.
Did that and unfortunately mine is still the same.
@amgonzo , did you try to swipe down or to the right? If you can and get a screen, change your clockface. There’s something changed  with the new Version and some clockfaces get errors like “fatal error, stack overflow” .
delete your clock face and reinstall it a few days later.
i had the same issue.
Community Council MemberMario Dings | Rotterdam NL
Fitbit: Versa, Versa2, Sense. (Versa light) - Phone: Android. - Developer clockfaces.(Nederlands)
My fit it versa 2, I don't know if it is the watch itself or the app, is not registering when I do exercise but is now adding exercise and activities I have not done at hours I was not doing them. It's very disheartening
Mine registers everything but steps , its as though part of the update is
missing .
Since the update, my Fitbit is taking ages to sync and the time is wrong. No matter what I try it’s a good 15 minutes behind. I’ve reset my watch, tried the time zone thing but no luck. Anyone having similar issues?
mine is the same i have reset 3 times and still no different .
@MarkMM wrote:
Are these third party clock faces? If so, it'd be up to the creator to make sure it works with operating system updates.Just like with Computer software.
I see where you’re coming from but this looks like a bug in the firmware. I’ve seen the same problem in clock faces from other developers (eg the horizontal separators in Orb Redux). Is it up to third party developers to work around bugs in Fitbit’s OS? Maybe. But as a developer myself I’ve seen no communication from Fitbit to even acknowledge the issue, let alone explain how to circumvent it.
Anyway, I have reached out to the developer of the Heart Rate Monitor clock face, but no reply yet. From his Twitter feed, he now appears to use a different brand of fitness tracker, so my chances are slim of a workaround to this Fitbit OS issue. 😢
its not a third party clockface it is an app update my phone is android as
is my tablet does not work with either of them .
Went ahead and tried the update.  Still under warranty so, I'd just have you send me a new one if it  bricks my watch as it seems to have done for so many on this thread.  It seems to be OK, I'm going to head out for a workout to check shortly.  One thing though.  the watch (Versa 2) will not maintain it's WiFi connection (even when I set up within a few feet of the router).  I ultimately had to update via Bluetooth.
Is it possible that's what's happening to people here?  The watch gets so far along, WiFi drops, and install aborts mid-stream leaving a borked up watch?
maybe , my daughter has one and hers updated no problem the only difference
is her mobile is Apple .
When it decided to give me a screen I could change the face I’ve done so twice , I’ve also done a factory reset that took hours as versa kept going to a black blank screen , I’m now annoyed at the level of service from Fitbit , and no acknowledgment of their update issues
Sent from my iPhone
No I’m Only using Fitbit clockfaces , it’s now not giving me any kind of screen ... well apart from a big red battery with 0% in it
Sent from my iPhone
This is what mine does. But it has effect that no apps can be updated on
watch. My primary music service is gone. Look for that. If your apps are
currently up to date you're good.
They must have finally fixed the apple firmware.  They had a disclaimer at the top of the page of the of their site for months saying they knew about the problems.
Sent from Yahoo Mail on Android
I am a bit confused as I only got notification on Thursday to install
update others seem to have had it quite a while .
my versa wont log sleep or daily exercise and app on phone wont log
steps per hour , steps/floors/distance/calories so this upgrade is a right
c***up .
Hmmm, I have a "find my phone" app now....from FitBit no less.....and it works....
