08-13-2020 12:24 - edited 09-03-2020 14:34
Update 9/3/2020: This update should now be available to all customers. If you have any difficulty updating, make sure you are following the directions in this article, and then provide as many specific details as possible in your post so that we can assist.
We've started rolling out Fitbit OS 4.2 Firmware Update (71.6.19) for the Versa series.
We release firmware updates to all customers in phases. The update will be available to everyone soon, and a banner will appear in the app when you can install the update. If you don’t see the banner yet, check the app again later.
*Firmware releases are not distributed based on region or location and can reach anyone no matter where you reside. We do not recommend performing a factory reset to force the update to your device as your data will be lost and you may not get the update. Please be patient and wait until you see the update banner inside of the Fitbit app to begin the firmware download.
WHAT’S NEW AND FIXED
Release notes can be found here.
HOW DO I UPDATE?
Step by step instructions for updating your Versa device can be found here.
We recommend updating your Versa over a home Wi-Fi network as this can greatly reduce the time it can take to get set up. For more information on connecting your Versa to Wi-Fi, check out this article.
If you run into any trouble updating your Versa I recommend reviewing these troubleshooting tips.
Actively managing your weight? Find accountability buddies on the Manage Weight board
08-25-2020 07:02
08-25-2020 07:02
Why would you buy one? is your warranty up? If they broke it they should fix it.
08-25-2020 07:13
08-25-2020 07:13
I don't hold out a lot of hope, given Google's crappy record with customer support.
08-25-2020 07:21
08-25-2020 07:21
If they really wanted to fix it they would've by now. So many people are frustrated by this update.
08-25-2020 08:54
08-25-2020 08:54
I don't think you can blame google for this. As far as I'm aware the google acquisition hasn't been finalised and is still going through regulatory approval. Fitbit customer support has however always been a bit hit and miss. I a device has failed and it's still within warranty it should be replaced (given that repair isn't an option).
This firmware update does seem to be causing more problems than any update I can remember in over over 5 years of using fitbit devices so people might want to hold off doing the update and see if Fitbit come up with a newer firmware update that fixes the problems.
Having said that I did the update on my Versa last week and apart from the unadvertised impact on your data logged for the day you do the update it seems to be working OK. Battery life is no better or worse than it was before. It's actually pretty useless and I need to charge it every day but that seems to be the norm for a Versa much over one year old and you just have to live with it unless you're brave enough to attempt a battery replacement. I suspect mine has only a few months left before I'm down to something like 12 hours battery life and then it will be time for something new.
08-25-2020 12:02
08-25-2020 12:02
Heck to make sure your auto sleep isn’t on
08-25-2020 13:07
08-25-2020 13:07
My Versa hasn’t been syncing well for a while. I always update when prompted. I got a new phone yesterday and thought that was the problem, but today the screen would only show if you pressed the button, it was dark, but none of the settings would respond on the touchscreen, so I rebooted it and it’s absolutely dead - won’t turn on, screen doesn’t even light up when put on to charge. I NEED a watch for work!
08-25-2020 14:50
08-25-2020 14:50
This is what I was looking for. Really liking the Versa 2 and was hoping it would compute zones based upon HR Reserve and allow me to add in my own measured peak HR.
08-25-2020 15:21
08-25-2020 15:21
It appears I'm way behind on firmware. (35.70.8.0). How do I get more up to date?
08-25-2020 16:07
08-25-2020 16:07
08-25-2020 20:34
08-25-2020 20:34
So I would like to ask why are there so many problems with updates and syncing. I have a versa lite that has been inoperable for three months and zero resolution. It’s rather aggravating to see a new product when there are so many challenges with the versa. Shouldn’t you fix the continual problems on the versa platform before the company starts pumping out new products? Seems rather backwards to me? When thumbing through the countless pages of community issues and seeing $$$$ thrown away to see another device coming is very frustrating. Seems very unethical in my opinion.
08-25-2020 23:37
08-25-2020 23:37
The banner appeared yesterday, but I ignored it for a while, as I was competing in a couple of challenges. It's now disappeared. Will it come back, and if so, when?
08-26-2020 02:38
08-26-2020 02:38
I've read pages and pages of people having same issue with me. Initially I thought I am doing something wrong. But it's all about this update. I have tried everything. The live chat support after reading about the issue in the pre-chat summary simply disconnected the chat. This is a sign of high unprofessionalism. I regret not buying a different type of watch now. It's clear nobody cares enough about this version to actually fix it. Maybe they care only about the more expensive ones.
Meanwhile whst can we do? Throw our versas to the garbage.
08-26-2020 03:10
08-26-2020 03:10
I bought my versa2 only two weeks ago
my daughter bought hers last week
hers is on the new update firmware and mine is not
I did a factory reset before seeing this forum as that’s what other forums said to do
have I ruined my chances of getting firmware 71.6.19?
i am currently on firmware 70.8.0
thanks
brett sparling
08-26-2020 05:00
08-26-2020 05:00
Hi @BrettoSparling I'm pretty certain you'll get the update, it's probably just a matter of waiting a while. The updates are staggered to avoid pushing it out to everyone at the same time.
08-26-2020 05:04
08-26-2020 05:04
08-26-2020 10:30
08-26-2020 10:30
Have you had any success in updating? I am in the same boat at as you.
08-26-2020 10:35
08-26-2020 10:35
08-26-2020 11:21
08-26-2020 11:21
Hi, since the time I updated the firmware of my watch, I am seeing a blue screen and nothing else. Tried restarting the watch several times, but it doesn't work. I just see a dark blue screen and nothing else. Any suggestions on how to fix this?
08-26-2020 15:02
08-26-2020 15:02
MarreFitbit. I have the same issue as the The Executioner, after trying the factory reset (done because my Versa has been ‘losing time’ for several days now and everything I have tried hasn’t worked). I have found all the actions recommended here, but none work. I cannot clear the ‘Data Not Cleared, Sync and try again’ message. I have tried to setup the Versa, but it can’t be found by my iPhone. I know the Bluetooth connectivity on the phone works, because I have setup an old Charge 2.
Please can can you arrange for Support to contact me ASAP to effect resolution. I am extremely frustrated.
Many thanks.
08-26-2020 16:02
08-26-2020 16:02
Versa light model since update turns itself off every 5 seconds, vibrates, turns on then repeats cycle of off and on. Left hand button no longer works. Factory reset completed 2 hours later same issue!!!! Not good enough 😞
