12-04-2018
17:55
12:11
HeydyF
12-04-2018
17:55
12:11
HeydyF
I am currently almost 6,000 steps into my day and suddenly all my readings are zero'd out. 0 floors, 0 steps, 0 calories, -- for HR. But I am still getting my cues to move, and I still have steps and calories burned showing in the app. I have reset the fitbit twice with no resolution.
Best Answer12-04-2018 18:10
12-04-2018 18:10
That is really weird! I know you have already restarted a couple of times, but try a couple more times. If that doesnt fix it then first try turning the watch off for a few hours (Settings app on the watch and scroll down to About). When you restart it a couple of hours later (press any button), if it is still not displayimg your data, try a factory reset (settings app on the watch and scroll down to About). You will then need to set up again. If that doesnt cure it you will need to contact Support (link in my signature)
Helen | Western Australia
