05-31-2018 22:46
05-31-2018 22:46
Just unboxed and fully charged my new Versa tonight. No matter how long I let it charge, it shows 83% on the tracker.
The sync'd app on my phone indicates 100% fully charged.
Did I get a lemon and should immediately exchange? I've already wasted 1.5 hours trying to troubleshoot on such a simple thing .... a battery gauge that actually works??!??
Scott
05-31-2018 23:03
05-31-2018 23:03
Have you tried restarting the watch several times? If not, give it a go. If that doesnt work you could try a factory reset (settings app onnthe Versa, scroll down to About) Let us know how you go
Helen | Western Australia
06-01-2018 00:39
06-01-2018 00:39
Thx Nelly for your reply.
Tried multiple reboots. No change.
Tried to power down and leave it off for a while and let it charge more. No change.
Tried a factory reset. It failed and gave the error "Data not cleared Sync & try again". Spent considerable time figuring out l how to get past this message on the Versa.
Trying factory reset again now ... 5 hours later and this is still an issue.
I'm about out of patience with this and Fitbit.
Scott
06-01-2018 01:14
06-01-2018 01:14
Yeah mine will charge to 100% but then as soon as I take it off the charger it goes to 99%. It can never hold a 100% charge.
06-01-2018 09:22
06-01-2018 09:22
I don't know why this thread has a message marked as solving this problem. This problem is not solved. In fact, it has worsened.
Out of box, max charge on tracker: 83%.
After failed factory reset, max charge: 83%.
After successful factory reset 1, max charge: 63%.
After successful factory reset 2, max charge: 43%.
Here's the solution, I got a lemon and it's getting exchanged today.
Scott
After
