09-25-2018
18:38
06:01
AlejandraFitbit
09-25-2018
18:38
06:01
AlejandraFitbit
Does anyone have any tips in getting my Versa to connect to my WiFi? I have strong WiFi signal on everything but my Versa can not connect. Also, how do I get my music to my Versa without WiFi? Beginning to wish I never purchased this product! It counts steps while I am typing!
09-25-2018 19:21
09-25-2018 19:21
We have had exactly the same problem. Check your Wi-fi compatibility, apparently it won't connect to 5GHZ or public Wi-Fi networks etc, basically any Wi-Fi networks that require logins, etc. You may be able to connect via a hotspot.
09-26-2018
06:03
05:45
09-26-2018
06:03
05:45
A warm welcome to the Community @SandraGinn and @Edski0000 thanks for stopping by.
I appreciate all the efforts in trying to fix this issue and will be glad to help you out. Please take a look at the following links and follow the instructions provide there:
About the steps, your Versa might register some steps depending on your hand movement. You can try the restart process for this.
Let me know the outcome. ![]()
