10-18-2018 09:03
10-18-2018 09:03
My versa is around a month old, its decided to go crazy on me, the screen is basically unresponsive and when i try to scroll theough the menu it does its own thing! Its set alarms, it flicks from through the steps, heart rate etc really quickly on its own! I've tryed resetting it a couple of times but its still happening. I don't know what else to do
10-18-2018 10:42
10-18-2018 10:42
Try a Factory reset. If that doesnt fix it then you will need to contact Support (link in my signature)
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
10-18-2018 11:17
10-18-2018 11:17
So i tried what you recommend, ive can't do it or the versa just osnt doing it ive tried about 4 times. Ive deleted it and set it up again and thats not worked i guess im going to have to get in contact with fitbit. Thank you for your help
