07-02-2021 15:34
07-02-2021 15:34
OK, this has been a problem with the Versa since at least 2019, according to the topics I've seen in the forums. Mine just started about a month ago. I've done everything (reboot, factory reset, cleaned the buttons) that others recommended doing, but the alarm window keeps coming up. Drains my battery. My Versa battery now only lasts about a day. I've come out from work (can't have it with me at my job), was 85% before I went in to work, was down to 3% when I got out of work.
What's the real fix for this?
07-10-2021 17:18
07-10-2021 17:18
Are you saying the screen to set the alarm, or that the alarm goes off?
Do you have a quick start set for the alarm?
07-11-2021 09:50
07-11-2021 09:50
No, it's not that the alarm goes off. I even tried removing the alarm I did have set, and the alarm screen would still automatically pop up on the display. I've now removed this alarm so I have no alarms set. The Versa will still just pop up with the alarm screen in what seems to be some random thing.
Best Answer07-12-2021 04:46
07-12-2021 04:46
Have you setup a quick start function for the Alarm App?
By default it require the screen to be on, a few swipes, and a tap in the correct corner to open the Alarm App.
Best Answer07-12-2021 19:38
07-12-2021 19:38
As far as I know, I don't have one. This is frustrating, as it seems to be an intermittent problem. It's been a couple days now, and I don't remember seeing the screen pop up, and my battery is lasting longer.
