10-18-2019 14:40
10-18-2019 14:40
I have my Versa and MyFitnessPal linked. On my Versa I track active minutes, usually 60 per day, not a specific activity. In the MyFitnessPal app diary I track food and exercise - i.e. elliptical 60 minutes 10 calories. This has worked fine - active minutes, calories burned, all work out and appear on Versa, Fitbit app and MyFitnessPal app. This works well because I have other apps that sync with MyFitnessPal to give me points etc for my exercise.
The last few days, I do 60 minutes elliptical (2 x 30 with interval in between), the Versa shows 60 active minutes, then I enter the info into My Fitness Pal and the active minutes on the Versa go to 30. If I delete the exercise from MyFitnessPal the active minutes on the Versa goes back up to 60!
There must have been an change in the two apps. Does anyone have any ideas to get back to where I was?
Can MyFitnessPal be set just to get info from the Versa and not send info back?
Thanks in advance for any help.
10-22-2019 09:34
10-22-2019 09:34
@laurebabus It's great to see that you've visited the Fitbit Community! Sorry for the delay in my reply.
Let me help you with your MFP integration. The integration is designed to transferred logged activities on MFP to your Fitbit account. You can contact the developer to see if you can select what items are transferred to Fitbit or not syncing these activities on your MFP account if they don't affect your stats.
Let me know how it goes.
