04-21-2020 07:36
04-21-2020 07:36
Is the only way to use both watches is to create two accounts? Do I need two devices to do this? One is for the uhc motion program because versa 2 is not on the motion plan.
04-21-2020 08:14
04-21-2020 08:14
@Goegoe that would be a question for your health plan. Fitbit has no say on what they do.
I found some info here.
Your health plan does not comunicate with the actual tracker. They interface with your Fitbit account and I don't see why it would matter which tracker was used.. As long as the tracker recorded the needed info and the Versa line records all the data the Inspire HR does and then some more.
Unfortunately no the two trackers can not be connected to the same account and if they could, you can only where one at a time.
Best Answer04-21-2020 07:37
04-21-2020 07:37
Are there any plans to add versa 2 to the uhc motion app program?
Best Answer04-21-2020 08:14
04-21-2020 08:14
