10-31-2018 18:39
10-31-2018 18:39
Anyone else having issues syncing the Versa to an IPhone XR at the WiFi signal search?
I’ve restarted the phone, the Versa, I’ve turned Bluetooth on and off... but the Versa can’t find any WiFi networks (I can confirm the router is working properly and other devices are using the signal).
Best Answer10-31-2018 20:50
10-31-2018 20:50
You mention syncing is that the problem?
Or is it setting up the wifi the problem?
For wifi, make sure that the phone is connected to the wifi that you want the ionic to attach to. But since you say that the phone can not find the wifi, this would be the place to start.
11-01-2018 03:08
11-01-2018 03:08
11-01-2018 10:55
11-01-2018 10:55
I noticed the title says the phone can't find the wifi.
What shoukd happen.
Plug the tracker into it's powered up charger to turn on the tracker wifi
The phone should be connected to the wifi, the app gets the name of this wifi.
The user enters the wifi password.
The app communicates this info to the tracker through Bluetooth, and instructs the tracker to connect to the WiFi.
11-01-2018 17:45
11-01-2018 17:45
11-19-2018 13:16
11-19-2018 13:16
I feel better knowing I am not the only one with this issue.
i have taken the app on and off. Tried to reconnect. Removed and readied device. Nothing.
Best Answer11-19-2018 13:26
11-19-2018 13:26
Best Answer12-06-2018 15:23
12-06-2018 15:23
Hi, how do you do the extra forces updated?
Thanks
Best Answer12-06-2018 15:31
12-06-2018 15:31
Best Answer12-06-2018 16:42
12-06-2018 16:42
12-06-2018 22:39
12-06-2018 22:39
I updated my phone and turned the watch on and off and it then seemed to work.
