12-12-2018
08:45
17:39
EdsonFitbit
12-12-2018
08:45
17:39
EdsonFitbit
Has anyone else noticed that the Versa doesn't keep a charge that long, seems it's on the charger more than on my wrist. Any suggestions to make it last longer?
Moderator edit: added label
12-12-2018 09:06 - edited 12-12-2018 14:12
Hi, the battery usage of your Versa depends on a lot of things: the way you use it, which features you have enabled, etc etc. One simple thing you can do to save battery energy, is looking at what Clock Face you're using. The brighter your clock face is, the more battery will be used. F.i. I charged my Versa last saturday evening and now, wednesday, my battery is still 45% and the main thing I changed was the Clock face. Before changing that, my Versa lasted 3.5 days, now 5 to 6 days. Also the bigger the size of the Clock Face is, in kB's, the more energy it uses. My Clock Face is only 25 kB.
This is Clock Face I'm using:
