04-20-2020 12:12 - edited 04-20-2020 12:15
Hi,
Went on a bike ride with battery showing 100% and within 2hrs watch had shut down with no battery charge. Tech wanted me to shut down all my notifications etc from calls, messages , calendar and apps but what’s the point of having a watch where you can’t use all those features all the time. So I had a look at the settings screen once in bike ride activity (top right corner of watch screen, the cog) on settings screen scroll down the list and make sure the “Auto Pause is set to ON”, and the “Always on screen is set to OFF” My battery doing same activity the next day still had 95% left after completing the same bike ride, a massive difference.
I also changed the brightness setting of the watch to “Normal Brightness” Hope this helps someone else out too!!
05-05-2020 06:39
05-05-2020 06:39
Hi @Dazsmith34, due to the recent events, I apologize for the delayed response. However, it's great to see you in our Fitbit forums.
I'm sorry to hear that the battery of your Versa drains fast when you take a ride on your bike. I totally understand how you feel about the tips provided by our Support team in order to save battery life. We really appreciate your feedback and comments since this helps us to keep improving.
Thank you also for sharing the tips you took. I'm sure that this will help other users.
I'll be around if any question arises.
