01-07-2019 08:00
01-07-2019 08:00
Is anyone face battery draining issue with Versa after the Fitbit OS 3.0 upgrade. In my case versa battery is draining so fast it last only for 30 hrs, instead of 3-4 days.
I have contacted support they did battery drain test, and decided to replace my Versa.
If anyone else have the issue?
01-07-2019 09:31
01-07-2019 09:31
Hi, have a good look at the posts on this Versa Board about the battery issue after updating and you'll see a lot of posts from users with the same experience. So, you're not the only one.
01-07-2019 09:34
01-07-2019 09:34
I am having that issue as well.
01-11-2019 19:20
01-11-2019 19:20
Having same problem after the update. I used to be able to have the Versa for 4+ days on single charge, but now it’s a daily charging routine and sometimes it just died on me during my walk!
01-21-2019 14:06
01-21-2019 14:06
Exact same issue for me. 5 hours of life, tops, since I updated to 3.0 - the prior charge lasted me 4 days.
I did a is a factory reset and set it up again, same issue.
Indont see a fix fix being posted - has Fitbit acknowledged the problem at least?
01-21-2019 14:16 - last edited on 03-09-2020 16:42 by LiliyaFitbit
they are trying to blame the clock face I used. They gave me another one.
I would have them ship you a new one. That is ridiculous
Thank You
01-21-2019 15:16
01-21-2019 15:16
I am on hold now. I thought it was only in my head. I took a pic when I took it off the charger this morning at 9:09a went to check the time 5mins ago....Dead as a door nail😡, not even sure how long it has been dead. Then I remembered, it was dead Friday after my workout. And I thought I forgot to charge it....
01-21-2019 18:33
01-21-2019 18:33
I am having same issue. Heart rate monitor, and notifications are turned off. I turned off all day sync and didn't use any of the apps. I only have the preloaded apps and used a clockface made by fitbit. I had to contact support and performed the battery test. It lasted a whole 5 hours. I am now waiting on their response to the battery test.
01-22-2019 04:08
01-22-2019 04:08
Thank
@varoyer wrote:I am having same issue. Heart rate monitor, and notifications are turned off. I turned off all day sync and didn't use any of the apps. I only have the preloaded apps and used a clockface made by fitbit. I had to contact support and performed the battery test. It lasted a whole 5 hours. I am now waiting on their response to the battery test.
Thank Varoyer...I called last night and they have me doing a test today. I have only had it on about 30 mins and I have lost 5% power🤨😐
I feel some type of way that during my work day that I have to be distracted to check my device😐...
01-22-2019 05:27 - edited 01-22-2019 05:28
Thank You
Gail Neely
They’re also sending me a new one. Do you recommending updating the new one to OS 3.0?
01-22-2019 05:30
01-22-2019 05:30
You have no choice but to update to 3.0 when you get a new device.
07-03-2019 10:56
07-03-2019 10:56
Hi I'm having the same issue they keep sending me to a different place finally I've been given a ticket number to check the battery drain. Getting about 30 hours as well from 3 to 4 days.
