07-23-2021
14:56
05:10
07-23-2021
14:56
05:10
Versa been fully charged wore it for a few hours not a full day and the battery has died once again. Used to last about 3 days.
07-24-2021 05:12
07-24-2021 05:12
@Kendall93 Thanks for stopping by and for the details shared about the issue with your Versa.
As you may know, your Versa battery should last up to 4 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or animated clock faces. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Hope that helps.
Best Answer07-24-2021 05:53
07-24-2021 05:53
Best Answer07-24-2021 10:17
07-24-2021 10:17
Best Answer07-24-2021 23:18
07-24-2021 23:18
Best Answer07-28-2021 01:32
07-28-2021 01:32
Hi I haven't started to use anything different on the watch since this started happening. I am using a fitbit clock face and have been for a while don't change it often.
Best Answer07-30-2021 21:56
07-30-2021 21:56
Honestly I think it’s safest for you to reset to factory settings in the app and hope there newest up date is better than the last. I got an email saying it was ready. It’s of no use to me but it might save yours.
