07-31-2020
17:10
06:03
07-31-2020
17:10
06:03
For the past two weeks I have been charging the Versa overnight and only getting around 2 hours before it goes dark, Why????
08-01-2020 06:16 - edited 10-12-2023 18:28
Hi there @Jersymare, welcome to the Community Forums. Thanks for the details provided in your post about the battery short life of your Versa. I'll be glad to help you with this.
As per the description, it seems that it has insufficient power source. Where do you charge your tracker? Have you checked if by any chance the USB port or outlet is faulty? If you haven't done so, try a different port. A UL-certified wall charger will also work. Don't use a USB hub. Please note that for best results, don’t leave your device plugged in on the charger longer than overnight.
If you haven't done so yet, I suggest taking a look at this help article: Can I extend my Fitbit device's battery life?
On the other hand, if you have charging difficulties, please check the steps below:
Best Answer08-01-2020 06:16 - edited 10-12-2023 18:28
